TwinTurbo.NET: Nissan 300ZX forum - My other concern is if the STV valve is not blocked
Carlos Ramirez
on July 31, 2014 at 10:39 AM
I am going to work on this wont be able to update
posted by Carlos Ramirez
on July 31, 2014 at 02:27 AM
Could it be that my AC compressor itself failed and clogged the system and maybe even clogged the condenser? How can I check that?
NEW AC problem pressure relief valve went off
Carlos Ramirez
10:18:49 07/29/14
High pressure can only be caused by a blockage in
JMartz
12:42:00 07/29/14
high pressure can also be caused by inadequate airflow
aliaZ
12:34:28 07/30/14
Re:I can take you step by step
ZTom
12:27:40 07/30/14
I will call you later tonight :-) (n/m)
Carlos Ramirez
13:46:53 07/30/14
Re: NEW AC problem pressure relief valve went off
aliaZ
12:44:00 07/30/14
Re: Re: your condenser fan is not on
ZTom
14:19:38 07/30/14
thanks for all the answers
Carlos Ramirez
13:45:53 07/30/14
Re: thanks for all the answers
aliaZ
15:15:24 07/30/14
Carlos Ramirez
02:27:44 07/31/14
My other concern is if the STV valve is not blocked -
Carlos Ramirez
10:39:04 07/31/14
Re: My other concern is if the STV valve is not blocked
aliaZ
17:30:51 07/31/14
